290 Views, 1 Reply
iLogic Event Trigger creation to activate update?
Hey Everyone
Can someone assist me with setting an event trigger? the scenario i have is as follows.
I have custom IDW Borders that need to update with the sheet size, with some help i got the rule to change the border when the sheet size is changed, however i need to manually run the rule for the change to take place.
Is there anyway of setting a rule or trigger that when the sheet size is changed, the Local update icon appears and then when you hit update the rule changing the border is run?
I need this to Automate everything so i dont need to manually run the rule each time.
Thanks for your help.
I have attached the IDW
