10-08-2015
12:18 AM
- Mute
- Permalink
- Report
10-08-2015
12:18 AM
Here is the code that download drawing from the vault and open it.
But you'll have to modify it for his own use.
VB.net:
Imports Autodesk.DataManagement.Client.Framework.Vault
Imports Autodesk.Connectivity.WebServicesTools
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports ACW = Autodesk.Connectivity.WebServices
Imports System.Collections
Imports System.Windows.Forms
Public Class Otevr_zVault
Dim fileIters As System.Collections.Generic.ICollection(Of VDF.Vault.Currency.Entities.FileIteration)
Public Shared kontrola As String
Public Sub stahni_vykr()
Dim results1 As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("xxx", "xxxx", "Administrator", "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing)
If Not results1.Success Then
MsgBox("Error1")
End If
Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing
connection = results1.Connection
Dim m_inventorApp As Inventor.Application = Nothing
' get running Inventor
Try
m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Catch ex As Exception
MsgBox("Error2")
End Try
Try
If m_inventorApp Is Nothing Then
MsgBox("Error3")
Return
End If
Catch
End Try
m_inventorApp.Visible = True
Dim oDoc As Inventor.Document
oDoc = m_inventorApp.ActiveDocument
Dim fullfilename1 As String = oDoc.FullFileName
Dim vykr As String
If Not fullfilename1 = Nothing Then
If oDoc.DisplayName.EndsWith(".ipt") Or oDoc.DisplayName.EndsWith(".iam") Then
vykr = Microsoft.VisualBasic.Left(oDoc.DisplayName, InStrRev(oDoc.DisplayName, ".")) & "idw"
ElseIf oDoc.DisplayName.EndsWith(".idw") Then
vykr = oDoc.DisplayName
Else
vykr = oDoc.DisplayName & ".idw"
End If
Else
MessageBox.Show("Error4")
Return
End If
Dim oFolder3 As String = Microsoft.VisualBasic.Left(fullfilename1, InStrRev(fullfilename1, "\") - 1)
Dim oFolder2 As String = Microsoft.VisualBasic.Left(oFolder3, InStrRev(oFolder3, "\"))
If fullfilename1 = Nothing Then
MsgBox("Error5")
Return
End If
Dim fullfilename As String = oFolder2 & "Drawings\" & vykr
Try
Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing
Try
'convert local path string to vault format
Dim VaultPath As String = fullfilename
If VaultPath.Contains("D:\Vault_Working\") Then
VaultPath = VaultPath.Replace("D:\Vault_Working\", "$/")
ElseIf VaultPath.Contains("E:\Vault_Working\") Then
VaultPath = VaultPath.Replace("E:\Vault_Working\", "$/")
Else
MsgBox("Error6 " + VaultPath)
Return
End If
VaultPath = VaultPath.Replace("\", "/")
Dim VaultPaths() As String = New String() {VaultPath}
Dim DocService As ACW.DocumentService
DocService = connection.WebServiceManager.DocumentService
Dim files As ACW.File() = Nothing
Try
files = DocService.FindLatestFilesByPaths(VaultPaths)
Catch
End Try
Dim file As ACW.File
file = files(0)
oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, file)
MsgBox("Error7")
End Try
If oFileIteration IsNot Nothing Then
'get settings
Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(connection)
oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download 'Or VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Checkout
oSettings.AddEntityToAcquire(oFileIteration)
kontrola = "NE"
connection.FileManager.AcquireFiles(oSettings)
End If
Dim Rodice As New Rodice
Call Rodice.GetWhereUsed()
Return
Finally
VDF.Vault.Library.ConnectionManager.LogOut(connection)
End Try
m_inventorApp.Documents.Open(fullfilename)
kontrola = Nothing
End Sub
End Class
