09-04-2015
01:18 AM
- Mute
- Permalink
- Report
09-04-2015
01:18 AM
Hello together,
I have an add-in with a form.
How could I check if the form is open or not? This does not work:
'Ensure active document is a Drawing If m_inventorApplication.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then For Each form In m_inventorApplication.OpenForms If (form.name = "Form_To_Check") Then 'form is loaded so can do work 'if you need to check whether it is actually visible If form.Visible Then 'do work when visible End If Else Dim MyLocalForm As New Form_To_Check MyLocalForm.Show(New WindowWrapper(m_inventorApplication.MainFrameHWND)) End If Next End If
Thanks for your help
Georg
