BWMcDowell
457 Views, 1 Reply
save copy as idw to dwg yielding zip file
on 9-2-15 my ilogic code:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 20737 StartFragment: 314 EndFragment: 20705 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
' Set a reference to the DWG translator add-in.
Dim oDWGAddIn As TranslatorAddIn
Dim i As Long
For i = 1 To ThisApplication.ApplicationAddIns.count
    If ThisApplication.ApplicationAddIns.Item(i). _
    ClassIdString = _
    "{C24E3AC2-122E-11D5-8E91-0010B541CD80}" Then
        oDWGAddIn = ThisApplication. _
        Exit For
    End If
Next
' Check to make sure the add-in is activated.
If Not oDWGAddIn.Activated Then
    oDWGAddIn.Activate
End If
' Create a name-value map to supply information to the translator.
Dim oNameValueMap As NameValueMap = ThisApplication. _
    TransientObjects.CreateNameValueMap
Dim strIniFile As String = "O:\Templates\INVENTOR\EXPORT TEMPLATES\" & iProperties.Value("CUSTOM", "INI FILE")
' Create the name-value that specifies the ini file to use.
Call oNameValueMap.Add _
    ("Export_Acad_IniFile", strIniFile)
' Create a translation context and define ' that we want to output to a file.
Dim oContext As TranslationContext = ThisApplication.TransientObjects. _
    CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
    If Not System.IO.DIRECTORY.Exists(iProperties.Value("CUSTOM", "DWG PATH")) Then
    System.IO.DIRECTORY.CREATEDIRECTORY(iProperties.Value("CUSTOM", "DWG PATH"))
    End If
' Define the type of output by specifying the filename.
Dim oOutputFile As DataMedium = ThisApplication. _
    TransientObjects.CreateDataMedium
    oOutputFile.FileName = iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE")
    If System.IO.FILE.Exists(iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE")) Then
    System.IO.FILE.DELETE(iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE"))
    End If
' Call the SaveCopyAs method of the add-in.
Call oDWGAddIn.SaveCopyAs _
    (ThisApplication.ActiveDocument, _
          oContext, _
          oNameValueMap, _
          oOutputFile)
saved a copy of my file to a specific sub folder as DWG
on 9-3-15 it saved it inside a zip file
I had already followed cathy's advice on editing the registry found here:
http://forums.autodesk.com/t5/inventor-general-discussion/save-copy-as-acad-dwg-zip-file/td-p/223026...
any advice to fix this now?
BWMcDowell
in reply to: BWMcDowell
mine did that suddenly recently starting last month
the work around is manually export first
it was caused by my network drives not connecting properly
when I opened a file in autocad here were red x's on network drives
changed a few things to get it to work again :
disabled power saver on my nic
disabled intel pro service
changed group policy to wait until network has initialized
set autocad services to delayed start
hope this helps
