phila
in reply to: MechMachineMan
The way it is working it saves both files then creates the step file of the triggered file. The assembly does not have a trigger. Only want STEP files created on triggered files
If it can be done, yes, save the triggered part to the appropriate STEP FILES folder even if it is not in the same folder as the assembly being worked on.
It has not created a folder in the wrong place.
Delete is fine..
