MechMachineMan
in reply to: phila
@phila wrote:
There are instances where an assembly from the Common Parts folder is used on the different models of the product. They are not in a library like a switch or knob. If changed, it is for all model of the product. If they become unique, they get a new part number.
Product
             Common Parts
             Model 1
                          STEP Files
             Model 2
                          STEP files
If I edit a part within the context of an assembly then finish edit without saving, then change something in the assembly and do a save, the standard dialog comes up asking if I want to save both files.
I click ok and both files are saved. The sub part which has the trigger to save as STEP when saved, gets run, which is fine but it saves the part with all the parts of the assembly not that part itself.
Inventor sees the assembly as the basis for the STEP file not the part being triggered and creates the STEP file with the correct name of the triggered file but with all the assembly parts.
Hope this makes sense.
So you want it to save both files from the assembly if you editted a part in place, and not only that but to asave it down to step and overwrite the old version in the appropriate folder?
Also, has the program also created a STEP folder in the wrong location, and do you specifically want the old versions to be deleted forever, or would you rather have them go to the recycle bin?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
