08-31-2015
06:08 AM
- Mute
- Permalink
- Report
08-31-2015
06:08 AM
Hi, I dont think so.
iLogic is set-up to be more of a macro feature - code that can be run, but doesn't return a value.
A better bet would to be to set up your program to include multiple subs/functions including the 2nd one you want to use as when you use a function you can return results.
ie;
Sub Main() 'Required name and line
oNewValue = YourFunction(args,,,) 'Function call line
'Additional functionality here or above
End Sub
Function YourFunction(arg1 as type, arg2 as type, ....) ' requires args
'Rule Functionality here
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
