- Mute
- Permalink
- Report
Export DXF to specific location
Hello, I have written some code to export a IDW sheet to a DXF to a specific location on our company network. Only problem is that not all users have rights to modify or delete the file (only the admin and the user who did the export have full rights)
You can see my iLogic rule here:
Imports System
Imports System.IO
Imports System.Security.AccessControl
'********************************************Zet DXF instellingen******************************************
Dim DXFAddin As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
'Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\temp\dxfout.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'********************************************Creëer path******************************************
'Dim sMaterial As String = ThisDoc.Document.ComponentDefinition.Material.Name
'Dim sThickness As String = Parameter("Thickness")
Dim sStockNr As String = iProperties.Value("Project", "Stock Number")
Dim sStockNrLinks As String
'trace.Writeline("Thickness: " & sThickness)
If sStockNr = "" Then
'vbLf = carriage return
sStockNr= InputBox("Stocknummer niet ingevuld !" & vbLf & "Geef stocknummer in:", "Onvolledig" , "")
End If
'Controleer of stocknummer 5 tekens bevat
If Len(sStockNr) <> 5 Then
i = MessageBox.Show("Ongeldig stocknummer ingegeven !", "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Return
End If
sStockNrLinks = Left(sStockNr,2)+"000" 'Voorlopig niet boven 100.000
trace.Writeline(sStockNr.ToString() & Chr(13) & sStockNrLinks.ToString() )
Dim sPATH As String
sPATH = "L:\ASCI\PRODUCTEN\" & sStockNrLinks & "\" & sStockNr
Dim sFilePath As String
sFilePath = sPATH & "\" & sStockNr & "_" & ThisDoc.FileName(False) & ".dxf"
'Dim UserAccount As String = "BASCULESROBBE\Users"
Dim UserAccount As String = "Everyone"
Dim FileInfo As IO.FileInfo = New IO.FileInfo(sFilePath)
Dim FileAcl As New FileSecurity
trace.Writeline("FileACL aangemaakt")
'FolderAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, InheritanceFlags.ContainerInherit Or InheritanceFlags.ObjectInherit, PropagationFlags.None, AccessControlType.Allow))
'FolderAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, InheritanceFlags.None, PropagationFlags.None, AccessControlType.Allow))
FileAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, AccessControlType.Deny))
trace.Writeline("Add accessrule ok")
FileInfo.SetAccessControl(FileAcl)
trace.Writeline("SetAccessControl ok")
'Kijk of path bestaat en creer indien het niet bestaat
If Not System.IO.Directory.Exists(sPATH) Then
System.IO.Directory.CreateDirectory(sPATH)
End If
'Set the destination file name
'oDataMedium.FileName = ThisDoc.PathAndFileName(False) & sheetname & ".dxf" 'same folder, or uncomment:
oDataMedium.FileName= sFilePath
'oDataMedium.FileName = "L:\ASCI\PRODUCTEN\14000\14001\14001_0150001.dxf\" & ThisDoc.FileName(False) & ".dxf" 'fixed folder
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Launch the dxf file in whatever application Windows is set to open this document type with
i = MessageBox.Show("Preview the DXF file?", "Title",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
The code executes till the FileAcl.AddAccessRule
I get the following error:
Error in rule: Rule4, in document: 0150092.idw
Some or all identity references could not be translated.
System.Security.Principal.IdentityNotMappedException: Some or all identity references could not be translated.
at System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean forceSuccess)
at System.Security.Principal.NTAccount.Translate(Type targetType)
at System.Security.AccessControl.CommonObjectSecurity.ModifyAccess(AccessControlModification modification, AccessRule rule, Boolean& modified)
at System.Security.AccessControl.CommonObjectSecurity.AddAccessRule(AccessRule rule)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Anyone got an idea what the problem might be ?
Thanks in advance,
Greetings
Cedric
- Mute
- Permalink
- Report
Thry this one
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim sSheetNumber As Integer
'step through each drawing sheet
Dim Response As MsgboxResult
For Each oSheet In oDrawing.Sheets
Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question")
If Response = MsgBoxResult.Yes Then
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos - 1)
'find the sheet numbe
sSheetNumber = Right(oSheet.Name, sLen - lPos)
End If
ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
'get DXF target folder path
oFolder = "c:\INVENTOR DXF FILES"
'Set the DXF target file name
oDataMedium.FileName = oFolder & "\" & sSheetName & sSheetNumber & ".dxf"
MessageBox.Show("DXF SAVED TO: " & oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
'Publish document
oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End If
Next
