08-27-2015
12:33 PM
- Mute
- Permalink
- Report
08-27-2015
12:33 PM
Place iLogic component save location
Hi everybody!
I would like to ask, if there is a way to change default behaviour of Place iLogic component to copy files near the target assembly. What we would like to do is to specify the path, where should the files be created. Is there some way to do this? In iLogic code, or in some kind of setup...
Thank you!
08-27-2015
01:03 PM
- Mute
- Permalink
- Report
08-27-2015
01:03 PM
Not in iLogic without creating some seperate rule that you have to run...
Only way I could see is to copy the file location to the clipboard before....
Or if there is an XML doc with the settings somewhere that you could change..
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
09-04-2015
01:27 AM
- Mute
- Permalink
- Report
09-04-2015
01:27 AM
Thank you for your response, if there would be a XML it would be great, but I couldn't find it. Right now I am thinking about some independent rule, which will manage it...
