08-22-2015
10:02 PM
- Mute
- Permalink
- Report
08-22-2015
10:02 PM
It's an iLogic snippet; the iLogic add-in for inventor contains 'shortcut'
snippets which make you type a little less. If you look in inventor
programming help it gives you full/proper methods and properties that would
work without the inventor add-in called if you ever expand to making
add-ins or external .exe's that access Inventor functionality.
Ie; ThisDoc is the shortcut for ThisApplication.ActiveDocment which is
actually an inventor shortcut for a call to the inventor app... which would
have to be called by something like m_InvApp = ApplicationId
(2938-9843-183838-1¥2¥)...... or at leat I'm pretty sure of haha
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
