- Mute
- Permalink
- Report
I have same requirement. But i have other problem. I created DXf file with Inventor, but my supplier said their machine does not reconigze my file. We use different symbel to mark bend space.
AEAHHMZ001-1-001 is a smple from supplier. 1-004-004-1 is from Inventor. I am not sure if i can change the configuration to make my DXf same as supplier's. Now i can see that the layer and bending symbel are different.
Please kindly take a look attached files, and give suggetion.
Jason
pball wrote:
The code for setting the file path is the second to last line in the main sub. I modified the line below to save the file in a subfolder named "DXF".
An example of how the code for the file name works.
original ipt file: c:\inventor\part1.ipt
full_path(oDoc.FullFileName) returns c:\inventor\
filename_noext(oDoc.FullFileName) returns part1
So adding those with other parts yields
dxf file: c:\inventor\DXF\part1-6.dxf
'This line saves the dxf. oDataIO.WriteDataToFile sOut, full_path(oDoc.FullFileName) & "DXF\" & filename_noext(oDoc.FullFileName) & "-" & TotQty & ".dxf"Hope that explains it well.
