bretrick30
I have an iLogic rule that kind of does what you are looking for.
This rule looks through my .idw sheets and finds the part/assembly I am looking for based off of the part number, in this example it is looking for an assembly that has a part number that begins with MF, MR, MS, MV, AR, AA, AW, AX, or AD.  What it is doing is changing the Designer of the model to match the current user.  Sometimes we have someone create the models and someone else create the drawings.
SyntaxEditor Code Snippet
oDoc = ThisDoc.Document
Dim oSheet As Sheet
Dim oSheets As Sheets
oSheets = oDoc.Sheets
Dim PNumCheck As String
For Each oSheet In oSheets
    Try
    RefDocProps = oSheet.DrawingViews.Item(1).ReferencedFile.DocumentDescriptor.ReferencedDocument.PropertySets
    PNumCheck = RefDocProps.Item("Design Tracking Properties").Item("Part Number").Expression
    Select Case Left(PNumCheck,2)
        Case "MF","MR","MS","MV","AR","AA","AW","AX","AD"
            RefDocProps.Item("Design Tracking Properties").Item("Designer").Expression = ThisApplication.Username
    End Select
    Catch
        MessageBox.Show("Error: Finding assembly and overriding Designer." & vbNewLine & vbNewLine & oSheet.Name)
    End Try
Next
