- Mute
- Permalink
- Report
Hello all,
Im fairly skilled with Inventor but a complete noobie to macros/VBA's. I have some programming knowledge and would like some guidance in making a macro to do the following:
1. "Save Copy As" of a flat pattern that will be open
2. Request the user to input BOM quantity and assembly quantity
3. Multiply the BOM quantity by the assembly quantity to get an integer "Z"
4. Save the flat pattern as XXXXX-XX-XX-Z
Before I start coding I'd just like to know if this is possible and any advice I can get.
Brendan
- Mute
- Permalink
- Report
This is definitely possible and not that difficult. Here is some code I put together from something similar I had. It will prompt for the two quantities and multipy them, if the flat pattern doesn't exist yet it will create it, and then it will save the dxf in the same folder as the part with "-(totalquantity) added to the file name. Let me know how it works for you.
Public Sub Export_DXF()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveEditDocument
If (oDoc.FullDocumentName <> oDoc.FullDocumentName) Then
MsgBox "Can't export while editing a part in an assembly"
Exit Sub
ElseIf (oDoc.ComponentDefinition.Type <> kSheetMetalComponentDefinitionObject) Then
MsgBox "Not a sheet metal part Sorry."
Exit Sub
End If
Dim BomQty As Integer
BomQty = InputBox(Prompt:="Enter Bom Quantity", Title:="Bom Quantity")
Dim AsmQty As Integer
AsmQty = InputBox(Prompt:="Enter Assembly Quantity", Title:="Assembly Quantity")
Dim TotQty As Integer
TotQty = BomQty * AsmQty
'If flat pattern doesn't exist, create it and return to folded view
If (oDoc.ComponentDefinition.FlatPattern Is Nothing) Then
Dim oDef As ControlDefinition
oDoc.ComponentDefinition.Unfold
Set oDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartSwitchRepresentationCmd")
oDef.Execute
End If
' Get the DataIO object.
Dim oDataIO As DataIO
Set oDataIO = oDoc.ComponentDefinition.DataIO
' Build the string that defines the format of the DXF file.
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=Outer&InvisibleLayers=IV_Tangent;IV_Bend;IV_Bend_Down;IV_Bend_Up;IV_Arc_Centers"
' Create the DXF file.
oDataIO.WriteDataToFile sOut, full_path(oDoc.FullFileName) & filename_noext(oDoc.FullFileName) & "-" & TotQty & ".dxf"
End Sub
Function filename_noext(spth As String)
'Returns filename without extension from full path
If (spth <> "") And (InStr(spth, ".")) And (InStrRev(spth, "\") < InStrRev(spth, ".")) Then
filename_noext = Mid(spth, InStrRev(spth, "\") + 1, InStrRev(spth, ".") - InStrRev(spth, "\") - 1)
ElseIf (spth <> "") And Not (InStr(spth, ".")) Then
filename_noext = Mid(spth, InStrRev(spth, "\", Len(spth)) + 1, Len(spth))
Else:
filename_noext = ""
End If
End Function
Function full_path(spth As String)
'Returns full path minus filename, trailing slash is included
If spth <> "" Then
full_path = Left(spth, Len(spth) - (Len(spth) - InStrRev(spth, "\")))
Else:
full_path = ""
End If
End Function
- Mute
- Permalink
- Report
THANK YOU SO MUCH!
That works beautifully.
One more question, where does the code describe where to save the dxf to?
I would like it to go into a sub-folder named "DXF" that is in the same folder as the part I am exporting.
Thanks again,
Brendan
- Mute
- Permalink
- Report
The code for setting the file path is the second to last line in the main sub. I modified the line below to save the file in a subfolder named "DXF".
An example of how the code for the file name works.
original ipt file: c:\inventor\part1.ipt
full_path(oDoc.FullFileName) returns c:\inventor\
filename_noext(oDoc.FullFileName) returns part1
So adding those with other parts yields
dxf file: c:\inventor\DXF\part1-6.dxf
'This line saves the dxf.
oDataIO.WriteDataToFile sOut, full_path(oDoc.FullFileName) & "DXF\" & filename_noext(oDoc.FullFileName) & "-" & TotQty & ".dxf"
Hope that explains it well.
- Mute
- Permalink
- Report
Yup that worked again.
Any idea how to get material thickness from the sheet metal defaults?
For example here I would want 0.1875 to appear.
I'm looking on other forums as well but no luck so far.
Brendan
- Mute
- Permalink
- Report
I have same requirement. But i have other problem. I created DXf file with Inventor, but my supplier said their machine does not reconigze my file. We use different symbel to mark bend space.
AEAHHMZ001-1-001 is a smple from supplier. 1-004-004-1 is from Inventor. I am not sure if i can change the configuration to make my DXf same as supplier's. Now i can see that the layer and bending symbel are different.
Please kindly take a look attached files, and give suggetion.
Jason
'This line saves the dxf. oDataIO.WriteDataToFile sOut, full_path(oDoc.FullFileName) & "DXF\" & filename_noext(oDoc.FullFileName) & "-" & TotQty & ".dxf"Hope that explains it well.
- Mute
- Permalink
- Report
You can use the following code to get the sheet metal thickness. The first two lines are not needed if you it with the code above as it already has those lines.
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oSheetMetalCompDef = oDoc.ComponentDefinition
Dim thick As Double
'Inventor returns the thickness in metric so it needs converted
thick = oSheetMetalCompDef.Thickness.Value / 2.54
- Mute
- Permalink
- Report
Thank you. I had that same code except I didnt know the value was returned as metric.
Finally the code is all done and it works perfectly. Thanks so much.
Brendan
- Mute
- Permalink
- Report
Weird, my ACAD doesnt recognize your supplier's drawing but it can open your drawing fine. Could it be that they have a different version of autocad? I'm using 2010 to open both files.
- Mute
- Permalink
- Report
I use AutoCAD2014. I saved the file as 2010dxf and attaced it again. Can you please try it again?
- Mute
- Permalink
- Report
Jason,
This is the line that determines the naming of the layers, colour of the layers and version of the dxf. It seems like you want to name OuterProfileLayer and Interior Profile Layer to be = to "Part" and change their colours to cyan. I'm not sure what the AM_5 layer is as it does not contain any objects in my autoCAD. There is also the code for IV_BEND and IV_BEND_DOWN in the code above. Perhaps you want to rename those?
- Mute
- Permalink
- Report
I can change the layer and color. But I do not know how to change the bending symbel as Ellipse. Can we change the bending symbel?
- Mute
- Permalink
- Report
sOut = "FLAT PATTERN DXF?AcadVersion=2013&OuterProfileLayerColor=0;255;255&OuterProfileLayer=Part&InteriorProfilesLayer=Part" '&TangentLayer=Part&TangentLayer=Part"
you can change the color by chaning the 0;255;255 to something else.
