- Mute
- Permalink
- Report
ilogic rule to change iproperties ipt part without opening file
Dear all
Anyone can help me .
I would like create a rule who call external rule to change iproperties in a ipt file without opening ipt.
Is there a command line like "auto.RunExternalRule(....).
I try it without succes.
anyone can explain any method.
Thank's very nice
PKZ
- Mute
- Permalink
- Report
Hi.
You must use an external application (.exe, etc) that accesses the Apprentice Server if you wish to run a rule to change iProperties outside of inventor.
You could also just make a rule to run from a blank document in inventor that accesses Apprentice Server, or you can just access the files as deferred/invisible from within a rule in inventor.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
Thanks mechmachine for you answer.
is there not à way with a rule like
modelname = ThisDoc.ModelDocument.FullFileName
namerule = "rulename.vb"
auto = iLogicVb.Automation
auto.RunExternalRule(modelname,"namerule")
Thanks for you help
- Mute
- Permalink
- Report
So you already have a rule in your .ipt that changes the iProperties to what you want?
- Mute
- Permalink
- Report
No in fact i want to call an external rule who change iproperties in the .ipt from the .idw opened.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
yes i have already rules but i don't know how run it into a .ipt from .idw
thank's
- Mute
- Permalink
- Report
So to clarify some more, this pre-written rule is used in the ipt's by the user even when it isn't called by this new proposed rule?
Also, Is the intention to just run this rule from the idw, get the part document that corresponds with the idw, run the external rule, and only alter that single part?
Also, is it only ever supposed to alter 1 ipt at a time/ be run from the idw to only change iProperties in 1 file?
- Mute
- Permalink
- Report
ok
i frequently create .idw part
i have to change iproperties in this .idw but i also want to whange iproperties directly in the .ipt concerned like "iProperties.Value("project", "Creation Date" ) = Now" and others
it will be very usefull to me not opening and closing each .ipt 1
Thank you very nice for your help, i know that my english isn't very good but i also learn inthe end. ![]()
- Mute
- Permalink
- Report
Here is a sub routine I made that can accomplish what you want with minor modifications. I left in the proper way to change iProps in case you ever need it. You should only need to change things in ChangeIDWiProps Sub amd the ChangeModeliProps Sub.
You shouldn't need to uncomment anything to get it working for you; just simply replace with the name of your external rule. HOWEVER, you SHOULD change your iProperty format in your external rule because simply using iProperties.Value("Project", ....) ONLY changes it for the active document, and will thus not work for running an external rule in a document that is not active (i.e.; it will just keep applying the changes inteded for the ipt to the idw). Good luck.
Sub Main()
Dim oDwgDoc As DrawingDocument
Try
oDwgDoc = ThisApplication.ActiveDocument
Catch
MsgBox("Use Drawing Document Instead")
Exit Sub
End Try
Dim oSheet As Sheet = oDwgDoc.ActiveSheet
Dim oDrawingView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oModelDoc As Document = ThisApplication.Documents.ItemByName(oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName)
ChangeIDWiProps(oDwgDoc)
ChangeModeliProps(oModelDoc)
End Sub
Sub ChangeIDWiProps(oDoc As DrawingDocument)
'iLogicVb.Automation.RunExternalRule([DOCUMENT OBJECT], [RULE NAME])
iLogicVb.Automation.RunExternalRule(oDoc,"Sheet Name Formatting.txt")
'http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
'oDoc.PropertySets.Item("Inventor Summary Information").Item("Author").Value = ""
'oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = ""
'oDoc.PropertySets.Item("Inventor Document Summary Information").Item("Manager").Value = ""
'oDoc.PropertySets.Item("Inventor User Defined Properties").Item("WO#").Value = ""
End Sub
Sub ChangeModeliProps(oDoc As Document)
End Sub
- Mute
- Permalink
- Report
I have an iLogic rule that kind of does what you are looking for.
This rule looks through my .idw sheets and finds the part/assembly I am looking for based off of the part number, in this example it is looking for an assembly that has a part number that begins with MF, MR, MS, MV, AR, AA, AW, AX, or AD. What it is doing is changing the Designer of the model to match the current user. Sometimes we have someone create the models and someone else create the drawings.
SyntaxEditor Code Snippet
oDoc = ThisDoc.Document Dim oSheet As Sheet Dim oSheets As Sheets oSheets = oDoc.Sheets Dim PNumCheck As String For Each oSheet In oSheets Try RefDocProps = oSheet.DrawingViews.Item(1).ReferencedFile.DocumentDescriptor.ReferencedDocument.PropertySets PNumCheck = RefDocProps.Item("Design Tracking Properties").Item("Part Number").Expression Select Case Left(PNumCheck,2) Case "MF","MR","MS","MV","AR","AA","AW","AX","AD" RefDocProps.Item("Design Tracking Properties").Item("Designer").Expression = ThisApplication.Username End Select Catch MessageBox.Show("Error: Finding assembly and overriding Designer." & vbNewLine & vbNewLine & oSheet.Name) End Try Next
- Mute
- Permalink
- Report
Thank's very nice MechMachineMan and bretrick30 for these answers.
I'll try to undersatnd the syntax of these rules and i'll return you feed back soon.
best regards
PK
- Mute
- Permalink
- Report
very well !
i try it , and it's very usefull for me.
i'll integrate it in my rules to easy change iproperties.
How can i check if some iproperties are not completed ?
Thank you very nice MechMachine
- Mute
- Permalink
- Report
By using:
If iProp.Value is Nothing
If iProp.Value = ""
If iProp.Value.IsNullOrEmpty
All 3 of these work by just checking the contents of the String Type Variable and any one would work for this case. If they have writing in them, but its not what you want, you have to compare the format then.
Ie; if your part number is supposed to be like 123-4567 we could check for the format usingthe like operator from vb.net (google "vb.net msdn like operator" for more info)
iProp.Value Like "###-####" ' # is a number wildcard; just means it's a digit, - is the symbol itself.
Or something simpler like:
iProp.Value Like "*-*" '* is a wildcard when using the like operator; can be any char(number/letter/symbol) and any number of chars
(https://msdn.microsoft.com/en-us/library/swf8kaxw.aspx)
