plausa.us
705 Views, 2 Replies
Modify Content Center Parts - weight
I am working with Inventor Professional 2015, in all our assemblies, parts the template we use have the Units set up for Mass is set to lbmass.
When I put any contents center parts standard or custom into an assembly, it I open that part and check the iproperties, under Physical and Update it calculates the part in Mass in kg.
When the custom parts were originally created with a table assocaited to them, they were set up with the lb set up.  Is there a  setting somewhere in Inventor or maybe it is in Vault (2015) that needs to be changed?  If so I can't find one.
I would really appreciate some help.  In the drawings and assemblies as a whole, it technically doesn't matter as the output will be in lbs.  It just when I open the piece individually and check it's weight default it shows kg.
I wouldn't want to open all custom parts and reset the Document settings, units in each that are created to lbs.
