in reply to: nmunro
Thanks for the assistance. The Evaluator function allows reading of the face areas without having to type it in like my first attempt was!
I've copied the code if anyone wants to look at it. It uses the area to determine and assign a mass based on the surface area density that you assign through an input box.
Sub SurfaceMeasurement()
'Check all referenced docs
Dim oDoc As Inventor.Document
Dim oSurfaceBodies As WorkSurface
Dim oSurfaceBody As SurfaceBody
Dim oFace As Face
Dim density As Double
Dim mass As Double
Dim allArea As Double
mass = 0
allArea = 0
tcount = 0
Set oDoc = ThisApplication.ActiveDocument
oDoc.SelectSet.Clear
'set surface bodies visibility
For Each oSurfaceBodies In oDoc.ComponentDefinition.WorkSurfaces
For Each oSurfaceBody In oSurfaceBodies.SurfaceBodies
For Each oFace In oSurfaceBody.Faces
allArea = allArea + oFace.Evaluator.area * 100
Next
Next
Next
density = InputBox("Please enter the mass per m^2: ", "Density", 2.477)
mass = allArea * density * 0.000001
MsgBox "The mass is " & CStr(mass) & " kg."
oDoc.ComponentDefinition.MassProperties.mass = mass
End Sub
