374 Views, 1 Reply
Custom Property Format - Fractional format with trailing zeros
I have a part template set up for creating flat bar.  The template has 3 parameters that I am trying to format as feet and inches with trailing zeros using the "Custom Property Format".  I am unable to figure out a way to do this.
When I set the Property Type to "Number" I can check off "Trailing Zeros" but I don't have the option for a "Fractional" format.
When I set the Property Type to "Text" I can set the format to "Fractional" but then I can't check off "Trailing Zeros"
How do I get this formated so a parameter with a value of 12" is shown as 1'-0"?
BWMcDowell
I wrote this bit of code to do just that in a string
it rounds up to the nearest 16th
Sub Main()
'CALCULATE RUNG TOTAL LENGTH
RUNGTOTLG = ""
FEET = Floor(RUNGLG/12)
INCH = Floor(RUNGLG - (FEET * 12))
FRAC = Ceil((RUNGLG - (FEET * 12) - INCH) *  16)
RUNGTOTLG = FEET & "'- " & INCH & TOFRACTION(FRAC) & Chr(34)
End Sub
Function TOFRACTION(NEUMERATOR As Integer ) As String
Select Case NEUMERATOR
Case 0
Return ""
Case 1
Return " 1/16"
Case 2
Return " 1/8"
Case 3
Return " 3/16"
Case 4
Return " 1/4"
Case 5
Return " 5/16"
Case 6
Return " 3/8"
Case 7
Return " 7/16"
Case 8
Return " 1/2"
Case 9
Return " 9/16"
Case 10
Return " 5/8"
Case 11
Return " 11/16"
Case 12
Return " 3/4"
Case 13
Return " 13/16"
Case 14
Return " 7/8"
Case 15
Return " 15/16"
End Select
End Function
hope this helps
