Owner2229
Ah, I see now. See the code below:
oData.FileName = "N:\PE\" & ThisDoc.FileName(False) & "_" & iProperties.Value("Project", "Revision Number") & ".stp"
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
