MechMachineMan
293 Views, 0 Replies
Create New Document with iLogic [Density Override]
Is there a way to create a new material/override a density for a material using iLogic?
My plans are to create an input box to ask the user for the real mass of an imported component, and then to divide that value by the volume of the component in order to create a "true average density" for the material so the inertial properties would be more correct.
So far I have come accross:
MaterialAsset.PhysicalPropertiesAsset Property MaterialAsset.PhysicalPropertiesAsset()
https://forums.autodesk.com/t5/inventor-general-discussion/using-ilogic-to-set-material-properties/t...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
