ekinsb
in reply to: CAD_CAM_MAN
Unfortunately, the "Project to Surface" command is not currently supported by the API.  The best way to request enhancements like this is to create a new post in the Inventor IdeaStation.
Depending on which options you want to use in the "Project to Surface" command, there might be a workaround you can use now.  If you were going to use the "Project along vector" option, the workaround is that you first create a surface extrusion of the curve so that the surface intersects the surface where you want the projected curve.  Then you can use the the Intersection Curve functionality in the API to create the curve.  This requires the creation of the extra extrude feature, but the resulting curve should be the same.
Brian Ekins
Mod the Machine blog
