- Mute
- Permalink
- Report
Hello all,
I wanted to remove style overrides from our titleblock. As there are many, many textboxes, I wanted to do this in an automated way.
There seems to be an issue with writing to FormattedText property.
The code is like
Inventor.Application invApp;
invApp = (Inventor.Application)System.Activator.CreateInstance(System.Type.GetTypeFromProgID("Inventor.Application"));
DrawingDocument drawDoc = (DrawingDocument)invApp.Documents.Open(@"Z:\_pdm\flg\Administration\Inventor\2014\Templates\Drawing_DE_EN.dwg");
TitleBlock tBlock = drawDoc.ActiveSheet.TitleBlock;
DrawingSketch sketch = tBlock.Definition.Sketch;
TextBoxes tboxes = sketch.TextBoxes;
foreach(TextBox tbox in tboxes)
tbox.Style = drawDoc.StylesManager.TextStyles["Iso"];
String text = tbox.FormattedText;
tbox.FormattedText=tbox.FormattedText.Replace("ISOCPEUR", "ISOCP");
drawDoc.SaveAsInventorDWG(@"c:\temp\test.dwg",true);even if I say
tbox.FormattedText = tbox.FormattedText
without changing anything, this still causes an exception.
Best regards
Erik
- Mute
- Permalink
- Report
Try
tbox.FormattedText=text.Replace("ISOCPEUR", "ISOCP");Or even:
String text = tbox.Text;
tbox.Text=text.Replace("ISOCPEUR", "ISOCP");That's what I would try...
- Mute
- Permalink
- Report
that has been my first try. Somewhere on the internet it says there might be problems with custom iProperties.
tbox.Text cannot be used in my opinion, as I do not want to change the text but the formatting.
Best regards
Erik
- Mute
- Permalink
- Report
Solved it.
I forgot to enter edit mode for the titleblock sketch
tBlock.Definition.Edit(out sketch);
That did the trick.
Best regards
Erik
- Mute
- Permalink
- Report
Hi Erik,
I had the same problem some time ago, I tried to change the formatted text with the "Replace" function and something went wrong.
Then I've tried the following solution and it started working properly
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
