Balaji_Ram
Hi Yogesh,
You should be using a 3d sketch, add a work point and use the sketch point from "p1" that you already have from the 2d sketch.
the SketchLine3D can then be used to create a path, if you wish to sweep the profile along the normal direction.
        Dim oSketch3d As Sketch3D
        oSketch3d = partDoc.ComponentDefinition.Sketches3D.Add
        Dim wp2 As Inventor.WorkPoint
        wp2 = oCompDef.WorkPoints.AddFixed(oTG.CreatePoint(0, 0, 1))
        Dim oLine As SketchLine3D
        oLine = oSketch3d.SketchLines3D.AddByTwoPoints(skp1, wp2, False, 1)
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
