06-19-2015
08:14 AM
- Mute
- Permalink
- Report
06-19-2015
08:22 AM
- Mute
- Permalink
- Report
06-19-2015
08:22 AM
Possibilities for what you may mean here:
1. Not having parts in assemblies grounded, and then after in-place editting the part, it shifting because it isn't properly grounded or constrained.
2. Editting Extrusions in an assembly, and changing the location of faces of the part, which in turn chages the model to fit the constraints.
3. Extrusions on Extrusions in a part file moving when a face changes.
.... Needless to say, unless you have parts properly constrained or grounded, they will move when you change the geometry of faces on them.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
