Hi Justin,
I've make some tests with this VBA code and it work fine.
But if you convert it in Ilogic, doesn't work.
Sub test()
    Dim oDoc As DrawingDocument
    If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then ' TESTED ON THE DRAWINGDOCUMENT
        Set oDoc = ThisApplication.ActiveDocument
        Call oDoc.Parent.CommandManager.PostPrivateEvent(kFileNameEvent, "FULL PATH AND FILENAME.iam") 'FULL FILENAME WITH FULL PATH
        Call oDoc.Parent.CommandManager.ControlDefinitions.Item("DrawingBaseViewCmd").Execute
        Set oDoc = Nothing
    End If
End Sub
I think this is a good start for you.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
