MechMachineMan
273 Views, 1 Reply
How to Pass a file to DrawingBaseViewCmd
As the title says I'm wondering how to pass a file to the Control Definition so that it automatically has that file selected to insert in..
SyntaxEditor Code Snippet
DrawingBaseViewCmd
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
oDoc = ThisApplication.Documents.Open("C:\Some Assembly.iam",True)
oDoc.Close
Dim oControlDef1 As ControlDefinition
 oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingBaseViewCmd")
oControlDef1.Execute
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hi Justin,
I've make some tests with this VBA code and it work fine.
But if you convert it in Ilogic, doesn't work.
Sub test()
    Dim oDoc As DrawingDocument
    If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then ' TESTED ON THE DRAWINGDOCUMENT
        Set oDoc = ThisApplication.ActiveDocument
        Call oDoc.Parent.CommandManager.PostPrivateEvent(kFileNameEvent, "FULL PATH AND FILENAME.iam") 'FULL FILENAME WITH FULL PATH
        Call oDoc.Parent.CommandManager.ControlDefinitions.Item("DrawingBaseViewCmd").Execute
        Set oDoc = Nothing
    End If
End Sub
I think this is a good start for you.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
