GarySchmitz3154
1050 Views, 1 Reply
custom arrowheads
is it possible to create custom arrowheads to use for section lines. The company i work for uses an arrowhead that looks like this and i would like to reproduce it in inventor
Best Regards
Gary Schmitz
Dell Precision M3800
Core I7, 2.3GHZ, 16G Ram, Quadro K1100M 24In Monitor
Product Design Suite Premium 2016
3D Connexions Wireless
ProNest 2015
Hi Gary,
Sorry, Inventor at present does not have support for custom arrow heads for the section lines.
Its an Enum when using the Inventor API and the ones listed in the "Terminator" list box in the styles editor in Inventor are the possible values.
A workaround could be create a sketch symbols and insert them to mimic a custom terminator while the actual terminator is set as "None"
Sorry, I am aware that this is far from being an ideal workaround as the sketch symbol isn't going to move along with the section line nor
switch directions when the section view is reversed.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
