- Mute
- Permalink
- Report
I tried to add title block in many ways (using macro) but without success.
Here is a code:
Sub test()
Dim odrawdoc As DrawingDocument
Set odrawdoc = ThisApplication.ActiveDocument
Dim oNewTitleBlockDef As TitleBlockDefinition
Dim oSheet As Sheet
Dim titleblock As titleblock
Set oSheet = odrawdoc.ActiveSheet
Set oNewTitleBlockDef = odrawdoc.TitleBlockDefinitions.Item(1)
Set titleblock = oSheet.addTitleBlock(oNewTitleBlockDef)
' Call oSheet.addTitleBlock(oNewTitleBlockDef)
End Sub
I got run time error 5 on line :
what is wrong?
Michal
- Mute
- Permalink
- Report
Public Sub addMyTitleBlock()
Dim oDrawDoc As DrawingDocument
'Ensure the active document is a drawing
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Set oDrawDoc = ThisApplication.ActiveDocument
' get the Title blocks (definitions)
Dim oTitleBlks As TitleBlockDefinitions
Set oTitleBlks = oDrawDoc.TitleBlockDefinitions
' add a new title block definition
Dim oTitleBlk As TitleBlockDefinition
Set oTitleBlk = oTitleBlks.Add("myxTitleBlock")
End If
End Sub
- Mute
- Permalink
- Report
Ok, maybe I use wrong function.
I'm trying to put title block on drawing.
I'have two title blocks in template, and I want to put one of them to sketch.
I see that your code is trying to add next table to sketch resources.
- Mute
- Permalink
- Report
I mixed your code with mine:
Dim osheet As Sheet
Set osheet = oDrawDoc.ActiveSheet
Dim otitleblock As titleblock
Set oNewTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("myxTitleBlock")
Set otitleblock = osheet.AddTitleBlock(oNewTitleBlockDef)
End If
End Sub
And your myxtitleblock has been added to my Sheet.
Now I see that I have problems with prompts probably. I was sure if I leave it empty then is OK.
I will try to fix it and let you know.
- Mute
- Permalink
- Report
As it says in API Help, if the titleblock that you are trying to add has prompted entries in it, you must supply them as arguments to the .AddTitleBlock line or else the method will fail.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
For all asking in the future:
Dim osheet As Sheet
Dim sPromptStrings(1 To 17) As String
sPromptStrings(1) = ""
sPromptStrings(2) = ""
sPromptStrings(3) = ""
sPromptStrings(4) = ""
sPromptStrings(5) = ""
sPromptStrings(6) = ""
sPromptStrings(7) = ""
sPromptStrings(8) = ""
sPromptStrings(9) = ""
sPromptStrings(10) = ""
sPromptStrings(11) = ""
sPromptStrings(12) = ""
sPromptStrings(13) = ""
sPromptStrings(14) = ""
sPromptStrings(15) = ""
sPromptStrings(16) = ""
sPromptStrings(17) = ""
'Set oNewTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("myxTitleBlock")
'Set otitleblock = osheet.AddTitleBlock(oNewTitleBlockDef)
Set oNewTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item(1) 'here you may put your titleblock name in ("my titleblock name")
Set otitleblock = osheet.AddTitleBlock(oNewTitleBlockDef, , sPromptStrings)
End Sub
What is important for me : I had to write lines like
without them it is not working.
In my example I have 17 text prompts.
Thanks for directing me ... ![]()
- Mute
- Permalink
- Report
