klemen_zivkovic
in reply to: adam.nagy
Adam,
I havent even imagined, this superb level of service.
The results of your code is almost perfect - you will see that edges on outer shell that result from holes in part are not selected, but as linear edges they also must be cutted with plasma cutter.
Is there a way to select them also?
Thank you very much for fast response and anticipation how to solve this!
