rey_bustamante
287 Views, 1 Reply
Using AssemblyPropertiesCmd event and Custom Properties
Hi all,
I'm creating an add-in for Inventor 2015 that creates a custom property then automatically opens up the iProperties window in Inventor. I'm using the solution here and it works great:
http://forums.autodesk.com/t5/inventor-customization/display-iproperties-dialog-for-a-specific-part/...
The only issue is the iProperties window opens to the "General" tab. I'd like it to open to the "Custom" tab, rather than the "General" tab so the user can see the newly added property without having to click around. The only suggestion I saw for this was to call the Windows Forms SendKey function to tab over to the correct tab:
http://inventorhub.autodesk.com/discussions/threads/120/post/2717821
This doesn't work for me, but regardless it sounds like a rather awkward way to accomplish what I'm looking for.
Is there a way through the API to either open directly to the "Custom" tab, or a way to navigate to it once the iProperties window is open?
Thank you.
Hi all, just curious if anyone has a solution for this, I've been searching since posting and this seems to be a common problem with no official solution.
