Amit_11
I am not sure if you are using Ilogic rules to read the Excel table or The Excel table is embedded into the file. Here I am attaching a test file, in this file excell file is embedded and a rule has been added to the file, which is triggered on any change in parameter.
The result is moment the excel file is saved, the part gets updated.
If you are writing a ilogic code to read the excel file, then the treatment will be different.
