Red text in your code returns the reference of the top assembly document (that owns the rule), while you need in the part document.  As the top assembly does not have those parameters  nothing happens.
Dim openDoc As Document = ThisDoc.Document
If openDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
For Each docFile As Document In openDoc.AllReferencedDocuments
If docFile.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oParams As Parameters = ThisDoc.Document.ComponentDefinition.Parameters    <--- mistake
Dim oUserParams As UserParameters = oParams.UserParameters
'Look for Frame Gen Parameter and format it
Try
Dim oParam As Inventor.Parameter
'Enter the name of Paramter here
So please try  this line in the following form:
Dim oParams As Inventor.Parameters = docFile.ComponentDefinition.Parameters
Hope this helps.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
