05-19-2015
07:55 AM
- Mute
- Permalink
- Report
05-19-2015
07:55 AM
Here is my test for the flange feature #1 in your sheet metal model.
Sub Test()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As SheetMetalComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oFlangeFeatures As FlangeFeatures
Set oFlangeFeatures = oDef.Features.FlangeFeatures
Debug.Print "FlangeFeatures.Count = " & oFlangeFeatures.Count
' Get the flange feature.
Dim oFlange As FlangeFeature
Set oFlange = oFlangeFeatures.Item(1)
' Position the end of part marker to just before this feature so the
' edges are in their original state.
Call oFlange.SetEndOfPart(True)
Dim oFlangeDef As FlangeDefinition
Set oFlangeDef = oFlange.Definition
Dim oEdge As Edge
Set oEdge = oFlangeDef.Edges.Item(1)
Dim Length As Double
'calculation of the edge length
Dim oCurveEval As CurveEvaluator
Set oCurveEval = oEdge.Evaluator
Dim MinParam As Double
Dim MaxParam As Double
Call oCurveEval.GetParamExtents(MinParam, MaxParam)
Call oCurveEval.GetLengthAtParam(MinParam, MaxParam, Length)
Debug.Print "Length, cm = " & Length
' Set the stop node back to the bottom of the browser.
Call oDef.SetEndOfPartToTopOrBottom(False)
Beep
End Sub
Results:
FlangeFeatures.Count = 3 Length, cm = 10
Hope this could help.
cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
