beardrafting
541 Views, 2 Replies
Run iLogic from Assembly to affect all parts
I'm trying to quickly format parameters in parts with an external iLogic script from the assembly level.
I can run this script at the part level
Imports Inventor.UnitsTypeEnum
Dim oParams As Parameters
oParams=ThisDoc.Document.ComponentDefinition.Parameters
Dim oUserParams As UserParameters
oUserParams=oParams.UserParameters
'Look for Frame Gen Parameter and format it
Try
Dim oParam As Parameter
'Enter the name of Paramter here
Dim MyParam As String = "G_L"
oParam = oUserParams(MyParam)
oParam.ExposedAsProperty = True
'format Custom Parameter
Dim oFormat As CustomPropertyFormat
oFormat = oUserParams(MyParam).CustomPropertyFormat
oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
oFormat.Units="ft"
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
oFormat.ShowUnitsString = False
oFormat.ShowLeadingZeros = False
oFormat.ShowTrailingZeros = False
Catch
End Try
But when i add it to other scripts i've found to run from the Assembly level nothing happens....
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
If openDoc.DocumentType = 12291 Then
For Each docFile In openDoc.AllReferencedDocuments
If docFile.DocumentType = 12290 Then
Try
oFormat.Units="ft"
Catch
End Try
End If
Next
Else
MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
End If
Any ideas?
thanks!!!
