Well, I guess the software must be "self-healing".
I did a manual DXF output, and chose to save the .ini file with presets, and now the iLogic script is working again.
I didn't do anything but that.
If you have the problem described above, try doing a manual "Save As" dxf and save a configuration file of your settings, then try to run the script again.
