in reply to: fulvio81
Hallo Fulvio81,
Thanks for your reaction. But when I take your code to make a rule it returns with an error. I made the rule in the main ****. Is that correct.
This is the more info from the error:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.BOMViews.get_Item(Object Index)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
What am I doing wrong?
Toon
