- Mute
- Permalink
- Report
iLogic issues DXF export after computer rebuild
Howdy
I got a virus thhe week before last called the teslacrypt virus. I had to rebuild my computer from backup and I'm now having problems with iLogic scripts.
The PDF and STEP still works, but the DXF throws an error
Error in rule: Generate DXF, in document: 009-0016.idw
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
"More Info"
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.TranslatorAddIn.SaveCopyAs(Object SourceObject, TranslationContext Context, NameValueMap Options, DataMedium TargetData)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
My vault and vault files were apparently untouched by the virus, and so I used the iLogic Browser to add the PDF, STEP, and drawing DXF back in.
Of course, I didn't need to do that for the files to run these scripts that already had them added as a "before save" action. But regardless, none of them work.
I did not write them, I simply downloadedd them from our vault and added them in. One of the draftsman here found them on the internet. I had great luck running them before the virus. This is a brand new installation of windows and Inventor 2014 sp2.
Any ideas? Board would not let me upload iLogicVB so rename the file from iam
TB
