Hi matthew.claxton,
Can I understand all codes are tested with Inventor 2013? it is a version that we are not supporting now, but I gave a quick test in 2015. it looks the 1 and 2 codes can work, while 3 failed. but what I tested with is a empty sheet metal, so for code 3, the failure might because I am deleting the materials in the library.
anyway, could you share a test sheet metal ? I can diagnose for 1-3 together.
