04-23-2015
11:13 AM
- Mute
- Permalink
- Report
04-23-2015
11:13 AM
Hi rtrayes13,
Here is the same rule with a Try/Catch/End Try added that will handle the error created when a sheet doesn't have a parts list.
I hope this helps.
Curtis
Dim oDoc As Inventor.DrawingDocument
oDoc = ThisDoc.Document
Dim oPartslist As PartsList
Dim oSheet As Inventor.Sheet
'get folder (using the same path as this doc)
folderName = ThisDoc.Path
'look at each sheet
For Each oSheet in oDoc.Sheets
'get the first parts list on the sheet
Try
oPartslist = oSheet.PartsLists(1)
'replace colon in sheet name with underscore
oName = Replace(oSheet.Name, ":","_")
'export each parts list
oPartslist.Export(folderName & "\" & oName & ".xls", PartsListFileFormatEnum.kMicrosoftExcel)
Catch
End Try
Next
'tell the user the files were created
MessageBox.Show("New *.xls files created in: " _
&vblf & folderName, "iLogic")
'open the folder where the new folders are saved
Shell("explorer.exe " & folderName & "\" ,vbNormalFocus)
