- Mute
- Permalink
- Report
I could see this getting pretty interesting depending on how things are suppressed as if you suppress components in a lower level, it will make it a temporary level of detail, thus you will have to search through those to access parts.
You might have an easier time just listing all suppressed parts for the current state of the top-level assembly document, by ignoring the level of detail aspect completely and just testing suppression status.
Otherwise, I would say you will definitiely need to look into the RepresentationsManager.LevelofDetailRepresentations methods.
Looking at all of the methods under Level Of Detail representations, the most use it will be for you is to establish what LOD you are looking at, and chaning/traversing them. They dont contain any information about the suppression status of components, only the substitute parts that may be used instead.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
