1728 Views, 12 Replies
04-16-2015
11:46 AM
- Mute
- Permalink
- Report
04-16-2015
11:46 AM
I stumbled across some iLogic that I am having a hard time manipulating. I am looking to export Part Lists from multiple sheets ( pipe spools) of an IDW. I would like the code to export "SPOOL:*" to separate excel files called SPOOL#*. (Where each "*" is a sheet.) I am unsure create code that loops to the next sheet while writing the correct excel file. Any help or advice is appreciated.
Dim oDoc As Inventor.DrawingDocument oDoc = ThisDoc.Document Dim oSheet As Inventor.Sheet 'oSheet = oDoc.Sheets(1) ' first sheet oSheet = oDoc.Sheets("Sheet:1") ' sheet by name ' say there is a Partslist on the sheet. Dim oPartslist As PartsList oPartslist = oSheet.PartsLists(1) ' export the Partslist to Excel. ' folderName = "C:\temp" folderName = ThisDoc.Path oPartslist.Export(folderName & "\Partslist.xls", PartsListFileFormatEnum.kMicrosoftExcel)
