MechMachineMan
1317 Views, 1 Reply
Print to PDF & Specify Output File Name Without Changing Registry
Here is a program I wrote that will print to PDF using a programatic file name - Yes, this is a huge work-around, but it works!
NOTE: You must change the PDF print output in preferences to Print To Specified Output Folder (which should be an empty folder solely for the purpose of this program), and then add that to the program at the top instead of what I have there.
Imports System
Imports System.IO
Sub Main()
Dim oOutputFolder As String = "C:\Users\Rob\Desktop\ADOBE PRINT OUTPUT\"
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oStr As String
Dim oStr1 As String
Dim FNamePos As String
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject
Else
	MsgBox("Use A Drawing Document, Dummy.")
	Exit Sub
End If
Dim j As Integer: j=1
Dim k As Integer: k=1
k=InputBox("What Sheet Count Do You Want To Start On?", "Sheet Start", 1)
Dim oTargetDir As String = oFolderDlg
If oTargetDir = ""
	Exit Sub
End If
For j=k To oDoc.Sheets.Count
	oSheet=oDoc.Sheets.Item(j)
   	oSheet.Activate
 	FNamePos = InStrRev(oSheet.Name, ":", - 1)
	oStr1 = Left(oSheet.Name, FNamePos-1)
	oStr = iProperties.Value("Custom", "WO#") & "-" & oStr1
	oTarget = oTargetDir & "\" & oStr & ".pdf"
	Dim oCheck() As String
	oCheck = System.IO.Directory.GetFiles(oOutputFolder)
	If (oCheck IsNot Nothing And oCheck.Length>0)
    	MsgBox("PDF Output Had A File In It. Aborting Rule",, "RULE OVERRIDE")
    	Exit Sub
	End If
	oPDFPrint
	Threading.Thread.Sleep(30)
	If oMove(oOutputFolder, oTarget) = 0
    	MsgBox("Program Aborted",,"Program Notice")
    	Exit Sub
	End If
Next
MsgBox("Program Ran Successfully",, "Success Message")
End Sub
Function oFolderDlg
    Dim dialog = New System.Windows.Forms.FolderBrowserDialog()
'    dialog.SelectedPath = Application.StartupPath
	dialog.ShowNewFolderButton = True
'	openFileDialog1.InitialDirectory
    If System.Windows.Forms.DialogResult.OK = dialog.ShowDialog() Then
        oPath = dialog.SelectedPath
	Else
		MsgBox("No File Selected. Aborting Rule")
		oPath = ""
    End If
	Return oPath
End Function
Sub oPDFPrint
Dim oDrgPrintMgr As DrawingPrintManager
Dim oDrgDoc As DrawingDocument
   ThisApplication.SilentOperation = True 'Must Be Set to False at End.
   oDrgDoc = ThisApplication.ActiveDocument
   oDrgPrintMgr = oDrgDoc.PrintManager
   oDrgPrintMgr.Printer = "Adobe PDF"
   oDrgPrintMgr.ScaleMode = kPrintBestFitScale
   oDrgPrintMgr.PaperSize = kPaperSize11x17
   'oDrgPrintMgr.PaperSize =kPaperSizeLetter
   oDrgPrintMgr.PrintRange = kPrintCurrentSheet
   oDrgPrintMgr.NumberOfCopies = 1
   oDrgPrintMgr.Orientation = kLandscapeOrientation
   oDrgPrintMgr.AllColorsAsBlack = True
   oDrgPrintMgr.RemoveLineWeights = False
	oDrgPrintMgr.SubmitPrint
 ThisApplication.SilentOperation = False
End Sub
Function oMove(oOutputFolder As String, oTarget As String) As Integer
Dim watch As Stopwatch = Stopwatch.StartNew()
Dim watch2 As Stopwatch = Stopwatch.StartNew()
Dim oFile() As String
Dim r As String = 1
Dim oLimit As Boolean = True
Dim oAsk As Boolean = True
''Move this to the printing code up a level.
While watch.Elapsed.TotalMilliseconds < 15000 And oLimit = True
    While watch2.Elapsed.TotalMilliseconds < 2000 And oLimit = True
    oFile= System.IO.Directory.GetFiles(oOutputFolder, "*.pdf")
        If (oFile IsNot Nothing And oFile.Length>0)
            oLimit = False
            System.IO.File.Move(oFile(0), oTarget)
        Else
            If oAsk = True
                r=MsgBox("Keep Waiting For PDF to Print?", MsgboxStyle.OkCancel, "Dialog")
                If r = MsgBoxResult.Cancel
                    MsgBox("You don't like waiting, eh? Bye then.",, "Exit Message")
                    Return 0
                    Exit Function
                Else
                    oAsk=False
                    watch2.Reset
                    watch2.start
                End If
            End If
        End If
    End While
    oAsk = True
    watch2.Reset
    watch2.start
End While
If oLimit = True
    MsgBox("Program Stopped - Over time",, "Failure Message")
End If
watch.Stop()
watch2.Stop()
Return 1
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Please Kudos/Comment if you end up using this, just so I know if there is a point to sharing programs on here,
Thanks!
Justin K
