in reply to: MechMachineMan
Thank you - that sounds like what I need.  When trying it with some sample code found online, though, I get a "parameter is incorrect" error for the .Add line.  Code is below - and I have no idea what I should put into the oName variable, assuming I can get the code to go that far.
Any guidance would be appreciated.
Dim oTemp As String
Dim oDrawDoc As DrawingDocument
Dim oName As String
Dim oSheet As Sheet
Dim oModel As Document
Dim oFormat As SheetFormat
oTemp = "C:\Users\Public\Public Documents\Autodesk\Inventor 2014\Templates\English\Ticket Template.dwg"
oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, oTemp, False)
oModel = ThisApplication.ActiveDocument
oName = "А, 1"
oFormat = oDrawDoc.SheetFormats.Item(oName)
oSheet = oDrawDoc.Sheets.AddUsingSheetFormat(oFormat, oModel)
