EScales
516 Views, 1 Reply
iLogic Form to Populate Titleblock on Multiple Sheets
So, I've created a real nice form to automatically populate the fields in my titleblock.  I did this by creating custom iProperties in my template .idw and then when I edit my form, the input updates the iProperties which in turn, populate the appropriate fields in the title block.  It works great...until I added a second sheet to my .idw file.  When I go to the second sheet to populate the title block, all the input that I used for the first sheet is already populated on the second sheet.  If I change the input to make the secoind sheet correct, it changes the first sheet title block too.  Ugh!!  So, I'm realizing that because I'm populating custom iProperties, it doesn't matter how many sheets there are, there's only one set of custom iProperties, therefore they keep changing.
Is there any way around this problem.  Unfortunately, there aren't custom iProperties for each sheet, which I think would solve my problem...although I'd have to create all the additional sheets ahead of time in my template.  Essentially what I want is prompted entries for each sheet, but I want them on my custom iLogic form, instead of the standard prompted entry window popping up.
This whole thing started because I wanted to change the active standard to something different for C and D size sheets (which I got working fine).  I figured since I could do that with an iLogic form, why not just populate the rest of the title block while I'm at it.
Any suggestions??
MechMachineMan
in reply to: EScales
You are correct, .idw properties apply to the whole idw document.
The other way to do this is to have the titleblock pull properties from the parts that go in them.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
