1074 Views, 5 Replies
Controlling Number of Features in a Circular Pattern - iLogic
How do you control the number of features in a circular pattern(of a single part) with iLogic?  I can count them but don't know how to change them.  I can change the parameter directly but is there something like oCircularPatternFeature.NumberOfElements?
SyntaxEditor Code Snippet
Dim oDoc As PartDocument
Dim oCompDef As PartComponentDefinition
Dim oCircularPatternFeature As CircularPatternFeature
Dim oCircularPatternFeatures As CircularPatternFeatures
Dim dNumberOfBolts As Parameter
'Set the document
oDoc = ThisDoc.Document
'Set the component definition
oCompDef = oDoc.ComponentDefinition
'Set the circular pattern features collection
oCircularPatternFeatures = oCompDef.Features.CircularPatternFeatures
'Show the number of bolts
For Each oCircularPatternFeature In oCircularPatternFeatures
    If oCircularPatternFeature.Name = "BoltPattern" Then
        dNumberOfBolts = oCircularPatternFeature.Count
        MessageBox.Show("There are now " & dNumberOfBolts.Value & " bolts.", "Test")
    Else
    End If
Next
