GeorgK
1776 Views, 17 Replies
LevelOfDetailRepresentation
Hello together,
I am looking for a possibility to list all parts, assemblies and subassemblies which are suppressed by a LevelOfDetailRepresentation.
This works for an assembly without subassemblies:
Dim asm As AssemblyDocument
        asm = m_inventorApplication.ActiveDocument
        Dim acd As AssemblyComponentDefinition
        acd = asm.ComponentDefinition
        Dim rm As RepresentationsManager
        rm = acd.RepresentationsManager
        Dim nvm As NameValueMap
        nvm = m_inventorApplication.TransientObjects.CreateNameValueMap()
        Dim doc As AssemblyDocument
        Dim occ As ComponentOccurrence
        ListBox1.Items.Clear()
        ListBox2.Items.Clear()
        Dim lod As LevelOfDetailRepresentation
        For Each lod In rm.LevelOfDetailRepresentations
            ListBox1.Items.Add(lod.Name)
            ListBox2.Items.Add(lod.Name)
            Call nvm.Add("LevelOfDetailRepresentation", lod.Name)
            doc = m_inventorApplication.Documents.OpenWithOptions(asm.FullFileName, nvm, False)
            Call nvm.Clear()
            For Each occ In doc.ComponentDefinition.Occurrences
                If occ.Suppressed = True Then
                    ListBox2.Items.Add("    " + occ.Name + " Suppressed = " + Str(occ.Suppressed))
                End If
                ListBox1.Items.Add("    " + occ.Name + " Suppressed = " + Str(occ.Suppressed))
            Next
            ' Don't forget to close the document not used anymore
            If Not lod Is rm.ActiveLevelOfDetailRepresentation Then
                Call doc.Close(True)
            End If
        Next
Thank you very much
Georg
