- Mute
- Permalink
- Report
Hello together,
I am looking for a possibility to list all parts, assemblies and subassemblies which are suppressed by a LevelOfDetailRepresentation.
This works for an assembly without subassemblies:
Dim asm As AssemblyDocument
asm = m_inventorApplication.ActiveDocument
Dim acd As AssemblyComponentDefinition
acd = asm.ComponentDefinition
Dim rm As RepresentationsManager
rm = acd.RepresentationsManager
Dim nvm As NameValueMap
nvm = m_inventorApplication.TransientObjects.CreateNameValueMap()
Dim doc As AssemblyDocument
Dim occ As ComponentOccurrence
ListBox1.Items.Clear()
ListBox2.Items.Clear()
Dim lod As LevelOfDetailRepresentation
For Each lod In rm.LevelOfDetailRepresentations
ListBox1.Items.Add(lod.Name)
ListBox2.Items.Add(lod.Name)
Call nvm.Add("LevelOfDetailRepresentation", lod.Name)
doc = m_inventorApplication.Documents.OpenWithOptions(asm.FullFileName, nvm, False)
Call nvm.Clear()
For Each occ In doc.ComponentDefinition.Occurrences
If occ.Suppressed = True Then
ListBox2.Items.Add(" " + occ.Name + " Suppressed = " + Str(occ.Suppressed))
End If
ListBox1.Items.Add(" " + occ.Name + " Suppressed = " + Str(occ.Suppressed))
Next
' Don't forget to close the document not used anymore
If Not lod Is rm.ActiveLevelOfDetailRepresentation Then
Call doc.Close(True)
End If
Next
Thank you very much
Georg
- Mute
- Permalink
- Report
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
Hello Justin,
please could you help me? How could I get the suppressed parts and assemblies from subassemblies?
Thank you Georg
- Mute
- Permalink
- Report
In the Programming/API help there is an example about how to traverse an assembly. I think that's what you need to add to your code.
I paste it below:
Traverse an Assembly API Sample
Public Sub AssemblyCount()
' Set reference to active document.
' This assumes the active document is an assembly
Dim oDoc As Inventor.AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
' Get assembly component definition
Dim oCompDef As Inventor.ComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim sMsg As String
Dim iLeafNodes As Long
Dim iSubAssemblies As Long
' Get all occurrences from component definition for Assembly document
Dim oCompOcc As ComponentOccurrence
For Each oCompOcc In oCompDef.Occurrences
' Check if it's child occurrence (leaf node)
If oCompOcc.SubOccurrences.Count = 0 Then
Debug.Print oCompOcc.Name
iLeafNodes = iLeafNodes + 1
Else
iSubAssemblies = iSubAssemblies + 1
Call processAllSubOcc(oCompOcc, _
sMsg, _
iLeafNodes, _
iSubAssemblies) ' subassembly
End If
Next
Debug.Print "No of leaf nodes : " + CStr(iLeafNodes)
Debug.Print "No of sub assemblies: " + CStr(iSubAssemblies)
End Sub
' This function is called for processing sub assembly. It is called recursively
' to iterate through the entire assembly tree.
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence, _
ByRef sMsg As String, _
ByRef iLeafNodes As Long, _
ByRef iSubAssemblies As Long)
Dim oSubCompOcc As ComponentOccurrence
For Each oSubCompOcc In oCompOcc.SubOccurrences
If oSubCompOcc.SubOccurrences.Count = 0 Then
Debug.Print oSubCompOcc.Name
Else
sMsg = sMsg + oSubCompOcc.Name + vbCr
Call processAllSubOcc(oSubCompOcc, _
sMsg, _
iLeafNodes, _
iSubAssemblies)
End If
Next
End Sub |
I hope that's what you need
- Mute
- Permalink
- Report
Hello Rodrigo,
thank you very much for the code. The problem is to get the dependent representations from the main assembly and loop than througt the assembly.
Main.iam -> LOD1 ; LOD2 ; LOD3
SUB1.iam -> LOD1 ; LOD2 ; LOD3
SUB2.iam -> LOD1 ; LOD2 ; LOD3
Georg
- Mute
- Permalink
- Report
Hi Georg,
I see that the difficulty lies in trying to get the LODs from the subassemblies, as you cannot do it from the ComponentOcurrence, but probably you would have to access each subassembly individually to be able to use the RepresentationsManager object and get the LODs.
Unfortunately I am not so experienced in this kind of programming with assemblies, so I am afraid I cannot help you further with this issue.
Good luck!
- Mute
- Permalink
- Report
I could see this getting pretty interesting depending on how things are suppressed as if you suppress components in a lower level, it will make it a temporary level of detail, thus you will have to search through those to access parts.
You might have an easier time just listing all suppressed parts for the current state of the top-level assembly document, by ignoring the level of detail aspect completely and just testing suppression status.
Otherwise, I would say you will definitiely need to look into the RepresentationsManager.LevelofDetailRepresentations methods.
Looking at all of the methods under Level Of Detail representations, the most use it will be for you is to establish what LOD you are looking at, and chaning/traversing them. They dont contain any information about the suppression status of components, only the substitute parts that may be used instead.
- Mute
- Permalink
- Report
I've slightly changed the code of thr "Traverse an Assembly API Sample".
Now it prints names of suppressed components ignoring substitutes.
You may extend this code to loop through every LOD in your top assembly document.
Dim sMsg As String
Debug.Print "--- Assembly: " & oDoc.DisplayName
If Not oCompOcc.IsSubstituteOccurrence Then
If oCompOcc.Suppressed Then
Debug.Print "suppressed: " & oCompOcc.Name
Else
'empty SubAssembly - do nothing
Else
sMsg, _
iLeafNodes, _
End If
End If
End If
Next
Debug.Print
Debug.Print "No of suppressed nodes : " + CStr(iLeafNodes)
Debug.Print "No of sub assemblies : " + CStr(iSubAssemblies)
End Sub
Debug.Print "--- SubAssembly: " & oCompOcc.Name
If Not oSubCompOcc.IsSubstituteOccurrence Then
If oSubCompOcc.Suppressed Then
Debug.Print "suppressed: " & oSubCompOcc.Name
Else
Else
sMsg, _
iLeafNodes, _
iSubAssemblies)
End If
End If
End If
Next
End Sub
Hope this helps.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Try this sample please:
Sub BOM_Qty_Test()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
Set oBOM = oAsmDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = True
Dim oBOMView As BOMView
Set oBOMView = oBOM.BOMViews.Item("Structured") 'Structured
Dim oBOMRow As BOMRow
Dim TotalQty As Double
TotalQty = 0
For Each oBOMRow In oBOMView.BOMRows
TotalQty = TotalQty + oBOMRow.TotalQuantity
Debug.Print "ItemNumber = " & oBOMRow.ItemNumber & " Qty = " & oBOMRow.TotalQuantity
Next
Debug.Print "Total Qty = " & TotalQty
Beep
End Sub
BOMRow.TotalQuantityOverridden Boolean property could help you to detect if the TotalQuantity property has been overridden.
cheers,
Vladimir Ananyev
- Mute
- Permalink
- Report
Thanks for answer but ı need total ItemQTY (sum ItemQTY) in BOM
not Total QTY
- Mute
- Permalink
- Report
Then use BOMRow.ItemQuantity property.
You may look at the BOMQuery vba sample from the Inventor API Help.
cheers,
Vladimir Ananyev
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
thanks for your help..
Can ı another quession?
how do "user parameter" = Base Quantity in part
- Mute
- Permalink
- Report
Look at the following post: Use iLogic to Change Base Quantity
See Inventor API Help for the BOMQuantity.GetBaseQuantity method. It allows to retrieve the base quantity for the part. If the first argument is BOMQuantityTypeEnum.kParameterBOMQuantity then the second argument returns the parameter object. You can get parameter name to use it in your rule.
Vladimir Ananyev
- Mute
- Permalink
- Report
I want to use this way
iProperties.Value("Custom", "HAMMADDE MALİYET") = (iProperties.Value("Custom", "HAMMADDE KODU"))*(BaseQuantity)*1.05
- Mute
- Permalink
- Report
Can you help me this topic?
" I want to use this way
iProperties.Value("Custom", "HAMMADDE MALİYET") = (iProperties.Value("Custom", "HAMMADDE KODU"))*(BaseQuantity)*1.05 "
