04-03-2015
05:34 PM
- Mute
- Permalink
- Report
04-03-2015
05:34 PM
I figured it out:
oCylOrigPlane1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select the origin plane of the cylinder") oCylOrigPlane2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select the a co-planar origin plane of the rod") Dim oCompDef1 As ComponentDefinition = oCylOrigPlane1.Parent() Dim oCompDef2 As ComponentDefinition = oCylOrigPlane2.Parent() Dim oCompOcc1 As ComponentOccurrence = oAsmCompDef.Occurrences.AllReferencedOccurrences(oCompDef1).Item(1) Dim oCompOcc2 As ComponentOccurrence = oAsmCompDef.Occurrences.AllReferencedOccurrences(oCompDef2).Item(1) oCompOcc1.CreateGeometryProxy(oCylOrigPlane1, oAsmPlane1) oCompOcc2.CreateGeometryProxy(oCylOrigPlane2, oAsmPlane2)
This seems to be a workaround seeing as the intention is that there will ever only be one occurrence of each part in the assembly.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
