MechMachineMan
1572 Views, 4 Replies
How to Create Work Plane Proxy Given an origin plane in a part?
As the title says, I'm trying to get the work plane proxy for use in an assembly - I'm trying to create an assembly mate constraint for two origin planes from within parts.
oCylOrigPlane1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select the origin plane of the cylinder")
oCylOrigPlane2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select the a co-planar origin plane of the rod")
oCylOrigPlane1.Parent.CreateGeometryProxy(oCylOrigPlane1, oAsmPlane1) oCylOrigPlane2.Parent.CreateGeometryProxy(oCylOrigPlane2, oAsmPlane2)
 I cannot figure out how to get the ComponentOccurence that contains the selected workplane though :disappointed_face:
Any help would be much appreciated!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
