03-31-2015
11:09 AM
- Mute
- Permalink
- Report
03-31-2015
11:09 AM
Also, Rebuild does not work on drawing files. Best you can do it .Update. Which might be what fixes the other issue for you anyways.
so
For Each oDoc in ThisApplication.Documents.VisibleDocuments
If oDoc.DocumentType() = kAssemblyDocumentObject Or kDrawingDocumentObject
With oDoc
' .Activate
'.Rebuild
.Update
.Save
.Close
End With
Else
With oDoc
' .Activate
.Rebuild
'.Update
.Save
.Close
End With
End if
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
