bretrick30
You can use an If statement to control the layer.
For example, if you have a parameter in your drawing called "Material", the code will look like this.
SyntaxEditor Code Snippet
If Material = "Stainless Steel" Then
    ThisDrawing.Document.StylesManager.Layers("Layer Name").Visible = True
Else
    ThisDrawing.Document.StylesManager.Layers("Layer Name").Visible = False
End If
